AMERICAN POWER CONVERSION-APC SMX1500RM2U SMART-UPS X 1500VA RACK - TOWER
Includes: CD with software Documentation CD Installation guide Rack mounting hardware Rack Mounting support rails Removable support feet Smart UPS signalling RS-232 cable USB cable.
Output:
Output Power Capacity: 1200 Watts / 1500 VA.Nominal Output Voltage: 120V.Output Frequency (sync to mains): 47 - 63 Hz.Waveform Type: Sine wave.Output Connections: (8) NEMA 5-15R.
Input:
Nominal Input Voltage: 120V.Input Frequency: 50/60 Hz +/- 3 Hz (auto sensing).Input Connections: NEMA 5-15P.Cord Length: 8 feet (2.44 meters).Input voltage range for main operations: 82 - 143V.Input voltage adjustable range for mains operation: 75 - 154V.Maximum Input Current: 12A.Input Breaker Capacity: 20.0 A.Batteries and Runtime: Battery Type.Maintenance-free sealed Lead-Acid battery with suspended electrolyte: Leakproof.Typical recharge time: 3 hour(s).Replacement Battery: APCRBC115.RBC Quantity: 1.Extended Run Options: APC Smart-UPS X 1500VA Rack/Tower LCD 120V.
Communications and Management:
Interface Port(s): SmartSlot USB.Available SmartSlot Interface Quantity: 1.Control panel: Multi-function LCD status and control console.Audible Alarm: Alarm when on battery: Distinctive low battery alarm: Overload continuous tone alarm.Emergency Power Off (EPO): Yes.
Surge Protection and Filtering:
Surge energy rating: 645 Joules.Filtering: Full time multi-pole noise filtering: 5% IEEE surge let-through: Zero clamping response time: Meets UL 1449.Maximum Height: 3.50 inches (89 mm).Maximum Width: 17.00 inches (432 mm).Maximum Depth: 19.30 inches (490 mm).Rack Height: 2U.Color: Black.Units per Pallet: 16.00.
Environmental:
Operating Environment: 32 - 104 F (0 - 40 C).Operating Relative Humidity: 0 - 95%.Operating Elevation: 0-10000 feet (0-3000 meters).Storage Temperature: 5 - 113 F (-15 - 45 C).Storage Relative Humid
Price: 1055.55
