APC SMT1500RMUS APC UPS SMT1500RMUS SMART-UPS 1500VA LCD RM 2U 120V US BROWN BOX
Output:Output Power Capacity: 1000 Watts / 1440 VA
Max Configurable Power: 1000 Watts / 0 VA
Nominal Output Voltage: 120V
Output Voltage Distortion: Less than 5% at full load
Output Frequency (sync to mains): 57 - 63 Hz for 60 Hz nominal
Topology: Line Interactive
Waveform Type: Sine wave
Output Connections: (6) NEMA 5-15R
Input:Nominal Input Voltage:120V
Input Frequency: 50/60 Hz +/- 3 Hz (auto sensing)
Input Connections: NEMA 5-15P
Cord Length: 2.44 meters
Input voltage range for main operations:82 - 144V
Input voltage adjustable range for mains operation: 75 - 154V
Batteries and Runtime:Battery Type: Maintenance-free sealed Lead-Acid battery with suspended electrolyte: leakproof
Typical recharge time: 3 hour(s)
Replacement Battery: APCRBC133
RBC Quantity: 1
Communications and Management:Interface Port(s): SmartSlot USB
Available SmartSlot Interface Quantity: 1
Control panel: Multi-function LCD status and control console
Audible Alarm: Alarm when on battery: distinctive low battery alarm: configurable delays
Emergency Power Off (EPO): Optional
Surge Protection and Filtering:Surge energy rating: 459 Joules
Filtering: Full time multi-pole noise filtering: 0.3% IEEE surge let-through: zero clamping response time: meets UL 1449
Conformance:Regulatory Approvals: CSA FCC Part 15 Class A UL 1778
Sustainable Offer Status:RoHS: Compliant
REACH: REACH: Contains No SVHCs
Item Dimension (LxWxH): 9.88 x 23.38 x 23.75
Weight: 70.2 lb
Warranty Information: 2 years repair or replace
Price: 1264.34
