TYCON RPST1224-100-160 25W REMOTE PRO POWER SYSTEM 160W SOLAR PANEL 12V 102AH BATTERY 24V POE
Features
Complete remote power solution for off-grid operation
Weatherproof outdoor enclosure with a 100ah battery
Enclosures can be wall or pole mounted
High performance sealed lead acid batteries
PWM charge controllers
Specifications
Solar Panel Size:
160W
Rated Power Generation:
25W
PoE Output Voltage:
24V
12V Battery Capacity:
102Ah
Weight:
199 lbs
Price: 2180.01
© ® ™ 2017.
