The RPSTL RemotePro series outdoor power systems are designed for applications that require a primary off-grid power source to run various equipment. The vented weatherproof enclosures have generous space inside for mounting customer equipment. 1U rackmount feature is integral to the enclosure as are multiple DIN rail mounts. All enclosures are hinged and gasket sealed with locking latches for security. The latches can be locked using a standard supplied padlock.The enclosures can be mounted to a wall or pole with the included mounting bracket system. Poles up to 11 diameter can be accommodated.
Features
