TYCON SYSTEMS RPPL1248-36-30 REMOTEPRO 8W CONTINUOUS REMOTE POWER SYSTEM 48V POE VOLTAGE
The RemotePro series outdoor power systems are designed for applications that require a primary off-grid power source to run various electronics. The sealed and weatherproof enclosures have extra space inside for customer electronics. All enclosures are hinged and gasket sealed. The PL enclosure can accept a padlock or tamper seal. The ST enclosure is equipped with 2 tamper proof closures that are operated by a special key included.
Features- Complete remote power solution for off-grid operation
- Weatherproof uv resistant outdoor enclosures
- Enclosures can be wall or pole mounted
- High performance valve regulated sealed lead acid batteries
- Advanced battery charge controller protects against
- Overcharge and over discharge
Specifications- Rated Power - 8W continuous output with 6 hours peak sun
- Solar Panel Size - 12VDC 30W
- Battery System - 12VDC at 36Ah
- Battery Reserve Time at Rated Power - 27 hours
- Battery Type - Sealed Lead Acid AGM
- POE Output Voltage - 48VDC at 0.62A
- Secondary Output Voltage - 12VDC at 1.5A
- Load Disconnect Voltage - 11.0VDC
- Load Re-Connect Voltage - 12.0VDC
- Controller Self Consumption - <0.5W
- Enclosure Type - Polycarbonate
- Enclosure External Size - 17.5 x 12.5 x 6 in.
- Enclosure Internal Size - 14 x 10 x 5 in.
- Operating Temperature - 22F to +140F
- Battery Weight - 22 lbs.
Price: 757.59
