TYCON SYSTEMS RPPL2424-18-30 REMOTEPRO 8W CONTINUOUS REMOTE POWER SYSTEM 24V POE PORT
The RemotePro series outdoor power systems are designed for applications that require a primary off-grid power source to run various electronics. The sealed and weatherproof enclosures have extra space inside for customer electronics. All enclosures are hinged and gasket sealed. The PL enclosure can accept a padlock or tamper seal. The ST enclosure is equipped with 2 tamper proof closures that are operated by a special key included.
Features- Complete remote power solution for off-grid operation
- Weatherproof uv resistant outdoor enclosures
- Enclosures can be wall or pole mounted
- High performance valve regulated sealed lead acid batteries
- Advanced battery charge controller protects against
- Overcharge and over discharge
Specifications- Rated Power Generation - 8W
- Reserve Time @ Rated Power - 27hrs
- POE Output Voltage (DC) - 24V 1A
- Secondary Volts Out (DC) - 24V 1.5A
- Battery Capacity (Amp Hrs) - 18Ah
- Battery Voltage (DC) - 24V
- Battery Type - Valve Regulated Sealed Lead Acid /Absorbent Glass Mat (AGM)
- Battery Life - 5 Years
- Controller Type - Dual Input - Solar/POE Dual Output: Battery Voltage/POE with DCDC Converter
- Overcharge Protection - 28.6V
- Over-discharge protection - 22.0V
- Over-discharge recovery volts - 24.8V
- Controller Self Consumption - <0.5W
- Enclosure Type - Die Polycarbonate
- Enclosure External Size - 7.5 x 12.5 x 6 in.
- Enclosure Internal Size - 14 x 10 x 5 in.
- Solar Panel Dims - 21 x 20 in.
- Operating Temperature - 30°C to +60°C
- Battery Weight - 78 lb.
- Wind Speed Rating - 110MPH
Price: 757.59
