TYCON SYSTEMS UPS-PL1248-36 UPSPRO SERIES 30W 430VA OUTDOOR UPS BACKUP POWER SYSTEMS - 48V POE
The UPSPro series outdoor enclosures are designed for applications that require a backup power source in order to maintain uninterrupted service to customers. The enclosure is powered over a CAT5 network cable via Power Over Ethernet (POE) using a POE Supply/Inserter (included). Features include an advanced battery charge controller to protect against over-charging or over-discharging of the valve regulated sealed lead acid AGM batteries. Enclosures have multiple ports for CAT5 cable antenna cables/connectors or other cabling. They are vented to prevent residual buildup of hydrogen gas.
Features- Weatherproof uv resistant outdoor enclosures
- Powered over cat5 cable using poe and/or solar
- Generous interior space for customer electronics
- Wall or pole mounting
- Isolates customer equipment from power line surges
- High quality agm vr sealed lead acid batteries
- Advanced battery charge controller protects against overcharge and over discharge
Specifications- Rated Power - 30W 430VA
- Solar Ready - YES
- Charging System - 24VDC 60W over POE
- Battery System - 12VDC at 36Ah
- Typical Backup Time at 14W Load - 24 hours
- Battery Type - Sealed Lead Acid AGM
- POE Output Voltage - 48VDC at 0.62A
- Secondary Output Voltage - 12VDC at 1.5A
- Load Disconnect Voltage - 11.0VDC
- Load Re-Connect Voltage - 12.0VDC
- Controller Self Consumption - <0.5W
- Enclosure Type - UV Resistant Polycarbonate
- Enclosure External Size - 17.5 x 12.5 x 6 in.
- Enclosure Internal Size - 14 x 10 x 5 in.
- Operating Temperature - 22F to +140F
- Battery Weight - 22 lbs.
Price: 542.35
