TYCON SYSTEMS UPS-ST12-100 UPSPRO SERIES 144W 1200VA OUTDOOR UPS SYSTEMS - 12V 102AH GEL BATTERY
The UPSPro ST outdoor UPS systems are designed to provide up to 192W backup power. There is enough backup power to keep a wireless base station alive for many hours. The controller provides load control to make sure the batteries don't over-discharge. This greatly extends the life of the batteries. The load output is also regulated to be sure that the voltage doesn't exceed the maximum voltage allowed by the load. The system is powered from 120VAC or 240VAC power. In case of power failure the transition to battery power is seamless and automatic. Recovery is automatic. The controller supports GEL/AGM or wet batteries.
FeaturesSpecifications
Price: 1641.05
