TYCON SYSTEMS UPS-ST24-100-8-UBNT UPSPRO SERIES 192W 2400VA UBNT AND MICROTIK BACKUP POWER SYSTEM - 102AH BATTERY
The UPSPro UBNT outdoor UPS system is designed specifically for 24VDC POE equipment like that from Ubiquiti Mikrotik Tranzeo etc. The proprietary charge controller maintains the proper charge on the batteries to prevent over charge and controls the load to prevent over-discharge.
Features- 192w maximum continuous output
- 7 switched 24vdc poe ports 1 data uplink port
- Designed specifically for ubiquiti and mikrotik applications
- Isolates equipment from power line surges
- High performance gel sealed lead acid batteries
- Weatherproof nema 4x / ip65 uv resistant locking outdoor
Specifications- Load Voltage - 24VDC +/- 5%
- Maximum Load Output - 12A
- Minimum Load Output - 1A
- Storage Capacity - 102Ah 2400VA
- Battery Type - Non-Spillable Sealed Lead Acid GEL
- Battery Life (Typical) - 5 Years
- Charge Voltage - WET Equalize = 28.8V Float = 26.4V GEL Equalize = 28.4V Float = 27V
- Over-Discharge Protection - 21.5V Load Off 25.2V Load On
- Other Protections - Short Circuit Reverse Battery
- VAC Input Voltage - 100-270VAC 47-63Hz
- VAC Input Current - 3.5A @ 115VAC / 1.8A @ 240VAC
- Fuse - 6A Internal
- Self Consumption - <5W
- POE Switch Output - 7 POE Ports 20 to 24.5VDC @ Max 2A per port Shielded RJ45
- POE Switch - 10/100Mb IEEE802.3/IEEE802.3u Auto Crossover
- POE Protection - Over Temperature Over Current Short Over/Under Voltage Surge
- Enclosure Type - 24 x 15 x 14 in.
- Enclosure Internal Size - 23 x 14 x 12 in.
- Operating Temperature - 30°C to +60°C
Price: 2538.99
