TYCON SYSTEMS UPS-ST2424-50-UBNT UPSPRO SERIES 60W 1200VA UBNT AND MICROTIK SYSTEM - 24V 52AH GEL BATTERY
The UPSPro UBNT outdoor UPS system is designed specifically for 24VDC POE equipment like that from Ubiquiti Mikrotik Tranzeo etc. The system provides up to 60W of continuous total DC power on 4 switched power over Ethernet (POE) ports. There is also a data uplink port if an external data connection is desired. The system is powered over Ethernet cable from an included 150W AC to DC power supply with POE inserter.
Features- 60w maximum continuous output
- 4 switched 24vdc poe ports 1 data uplink port
- Designed specifically for ubiquiti and mikrotik applications
- Isolates equipment from power line surges
- High performance gel sealed lead acid batteries
- Operating temperature -30c to +60c
- Weatherproof nema 4x / ip65 uv resistant locking outdoor enclosure
Specifications- Battery Capacity - 24VDC 52Ah
- System Power Output - 60W Continuous
- POE Power Supply Input Voltage - 100-270VAC 47-63Hz
- POE Power Supply Output Voltage - 48VDC @ 3A
- Controller Solar Input - 8A Max (270W 24VDC Panel)
- Overcharge Protection - 28.6 +/- 0.3V
- Over-discharge protection - Load Off: 20.0 +/-0.3V Load On: 22.3 +/-0.3V
- Other Protection - Short Circuit Reverse Battery
- POE Switch Output - 4 POE Ports 20 to 24.5VDC @ Max 2A per port Shielded RJ45
- POE Switch - 10/100Mb IEEE802.3/IEEE802.3u Auto Crossover
- POE Protection - Over Temperature Over Current Short Over/Under Voltage Surge
- System Self Consumption - <1.5W
- Battery Type - Non Spillable Sealed Lead Acid GEL
- Battery Life (TYPICAL) - 5 Years
- Enclosure Type - Powder Coated Steel Security Locks Pole (2 to 4 in.) or Wall Mount
- Enclosure External Size - 24 x 15 x 14 in.
- Encl
Price: 1636.08
