TYCON SYSTEMS UPS-ST48-50 UPSPRO SERIES 288W 2400VA OUTDOOR UPS SYSTEMS - 48V 51AH GEL BATTERY
The UPSPro ST outdoor UPS systems are designed to provide up to 192W backup power. There is enough backup power to keep a wireless base station alive for many hours. The controller provides load control to make sure the batteries don't over-discharge. This greatly extends the life of the batteries. The load output is also regulated to be sure that the voltage doesn't exceed the maximum voltage allowed by the load. The system is powered from 120VAC or 240VAC power. In case of power failure the transition to battery power is seamless and automatic. Recovery is automatic. The controller supports GEL/AGM or wet batteries.
Features- Up to 192w maximum continuous output
- 12vdc 24vdc and 48vdc systems
- Isolates equipment from power line surges
- High performance gel sealed lead acid batteries
- Choice of 51ah (600va) to 204ah (2400va) battery capacity
- Operating temperature -30c to +60c
- Weatherproof nema 4x / ip65 uv resistant locking outdoor Enclosure
Specifications- Rated Power - 192W 2400VA
- Charging System - 120-240VAC
- Battery System - 48VDC at 51Ah
- Typical Backup Time at 80W Load - 24 hours
- Battery Type - Sealed Lead Acid GEL
- Secondary Output Voltage - 48VDC at 4A
- Load Disconnect Voltage - 40VDC
- Load Re-Connect Voltage - 51VDC
- Controller Self Consumption - <5W
- Enclosure Type - Powder Coated Plated Steel
- Enclosure External Size - 24 x 15 x 14 in.
- Enclosure Internal Size - 23 x 14 x 12 in.
- Operating Temperature - 22F to +140F
- Battery Weight - 148 lbs.
Price: 2451.02
