TYCON UPS-STL48-100 OUTDOOR UPS POWER SYSTEM WITH 24V AND 48V BATTERY 200W AND 4800VA BATTERY POWER
The UPSPro STL outdoor UPS systems are designed to provide up to 200 continuous watts of backup power. The controller provides load control to make sure the batteries don’t over-discharge. This greatly extends the life of the batteries. The load output is also regulated to be sure that the voltage doesn’t exceed the maximum voltage allowed by the load. The system is powered from 115VAC or 230VAC power. In case of power failure the transition to battery power is seamless and automatic. Recovery is automatic.
The systems feature a state-of-the-art manageable temp compensated MPPT battery charge controller with integrated monitoring/control and 7 port gigabit PoE switch. The controller is powered by a 65V 1200W AC to DC power supply. The vented weatherproof enclosures have generous space inside for mounting customer equipment. A 19” 1U rackmount feature is integral to the enclosure as are multiple DIN Rail mounts. The enclosure has security latches that can be secured using a customer supplied padlock. There are three cable gland ports for CAT5 cable solar and other cabling. There is a thermostatically controlled fan that automatically turns on when the temperature exceeds 45°C. The included bracket kit allows for the enclosure to be pole mounted or wall mounted.
FeaturesSpecifications
Price: 3968.80
